Increase mow height on YTH 24V48
   / Increase mow height on YTH 24V48 #1
davek78063
Pipe Creek, Tx
Mahindra 2538
All I have a Husqvarna YTH 24V48 and the max mow height is 4". The problem is I live in the country and don't have a manicured lawn so even at 4" it bottoms out. I was wondering if there are any mods I can make to increase the mower height by a couple inches. My first thought would be to put on larger tires. Are there any other options?
   / Increase mow height on YTH 24V48 #2
So, there isn't much you can do to raise the deck as the deck will end up hitting the frame. I have seen people change the tires - more so for traction issues which were basically Deere Gator tires which brought the rear up and still cleared the deck. This person had also installed golf cart tires on front to equal out the height. One could hope that they could do better traction wise. Field Trax Carlisle AT22.5X 10-8 TURF GUIDE 8.00X6 FRONT
Wouldn't that raise the height from the ground? I would think the entire frame would have more ground clearance.
   / Increase mow height on YTH 24V48 #4
How about getting a brush hog for your Mahindra?
I use my 3725 and brush hog for the rough stuff, and my Husq YTH for the lawn area around the house.
I use the Husqvarna for mowing under and around trees. As I move from one area to another it seems i am bottoming out. I realize that it is designed more to cut manicured lawns but I need something that is rugged enough to get get around the property so i can mow in areas that my tractor is too big for, mostly under trees. The problem is I need a couple inches more clearance for the deck. My wife also uses it as a utility vehicle to carry gardening tools around with her with an attached trailer.
500 Gallon Boom Sprayer (A50123)
500 Gallon Boom...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
Charlotte County (A50323)
Charlotte County...
2021 Chevrolet 4500 20FT Box Truck (A51692)
2021 Chevrolet...
2011 Nissan Frontier Pickup Truck (A53117)
2011 Nissan...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
