Incorrect Size Bucket
   / Incorrect Size Bucket #1
Boomer33
Bronze Member
Sullivan Co., NY State
NH Boomer TC33D & 1951 Ford 8N
My TC33D came with a 7308 Loader. The bucket is 68". According to the loader manual, 60" is the maximum size for use on the TC33D. The 68" is reccomended for use on the 1720 & 1920 tractors only.My dealer says he will exchange it for a 60", but feels I will have no problems using the one I have. It works great for snow removal use and I would like to keep it, but I am worried that it might be dangerous. I would appreciate hearing your opinions on this matter. Thank you,
Arthur
   / Incorrect Size Bucket #2
Boomer 33
There are only a couple of minor concerns with an oversize bucket. One is that it can make it more difficult to dig in hard soil with the extra width to push into the ground. Another is that you can more easily put too much weight in the loader (when your moving piles of gravel etc.) & not be able to lift it & then have to waste time dumping a little back out. The last thing is that you could possibly put excessive torque or stress on the loader frame when pushing hard or lifting / prying with just one outer corner of the bucket (with the extra leverage you have now)
The up side is that it will work wonders for snow & lighter materials. If you use common sense with it, it will probably be just fine & it may turn out to be more productive than the "right" one would be... especially if one of your primary uses is snow removal.
Troy
   / Incorrect Size Bucket #3
Arthur, I read your message and was thinking about an answer while I was reading Troy's message, and looks like he's already covered it all very well./w3tcompact/icons/smile.gif
Bird
HYSTER S50FT STRAIGHT MAST FORKLIFT (A51242)
HYSTER S50FT...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2016 TRAIL-EZE TE80HT 102" X 48' STEP DECK TRAILER (A51243)
2016 TRAIL-EZE...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
