In need of some engineering help
   / In need of some engineering help #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
I'm trying to avoid spending an exorbitant sum (at least to me) for a kit to make some modifications to a mower and need some help with what I'm reading on the exploded diagram of the items in question. Most are simply hardware items but I don't know the abbreviations being used and hope someone can help me.
Here's what I see I don't understand;
"HHCS 1/2 NC X 6 (then either CR5 or GR5)"
It looks like a 1/2" x 6" partially threaded bolt (possibly grade 5 if the abbreviation is GR5). What might the rest of it mean?
Also there is this;
"SLV 7/8 X 1 1/8 X 19/32 (NT or HT)"
On that one the picture is no help at all, I'm afraid.
I may come across something else as a move ahead with this, but those were the two that have me most confused right now. /forums/images/graemlins/crazy.gif Thanks in advance for your help with these. /forums/images/graemlins/smile.gif
Edited to change the 'NT' to '(NT or HT)' on the second item.
   / In need of some engineering help #2
I thought I knew a little about bolts. After about 45 minutes to an hour of searching Google and digging through Machinery's Handbook I now know a lot more. I could find no reference to a "HHCS" bolt. At first I thought it would be a hex high carbon steel but even a grade 8 is just quenched and tempered medium carbon. Your guess is as good as mine. I figure it's just a grade 5 bolt. /forums/images/graemlins/frown.gif The second item you listed is a sleeve but I have no idea what the "NT" is.
   / In need of some engineering help #3
Gary
HHCS = Hex Head Cap Screw.
1/2 NC X 6= 1/2-13 X 6" long. Grade 5.
SLV 7/8 X 1 1/8 X 19/32 NT /forums/images/graemlins/confused.gif
Could it be a V-belt Pulley?
   / In need of some engineering help #4
</font><font color="blue" class="small">( SLV 7/8 X 1 1/8 X 19/32 NT /forums/images/graemlins/confused.gif)</font>
I'm guessing with the info provided, but I'd say this is possibly a bearing with the dimensions being OD (outside diameter) ID (inside diameter) W (width) - but not necessarily in that order in this case.
The second one being a sleeve of some sort makes sense given where it is in the diagram. After I read the first three replies here with no one finding what 'NT' meant, I re-read the spec sheet I have (a copy of a fax, so you can imagine the quality /forums/images/graemlins/crazy.gif ) and determined that what I first read as 'NT' could well be 'HT' also.
I edited my posting to reflect that and made note of the edit. I hope this helps you help me. /forums/images/graemlins/smile.gif
   / In need of some engineering help #6
A sleeve or a spacer? Either way, I vote for HT. Heat treated for hardness. Anyway you can post the diagram?
I'm going to say it's a sleeve based on the 'SLV' abbreviation and on the fact that something looking very similar with the same type of description (three dimensions) actually has 'SLEEVE' on it's label. /forums/images/graemlins/cool.gif
Frankly, I'm not sure what the difference between a sleeve and a spacer going over a bolt might be, anyhow, other than possibly it's primary function and where it's greatest strength might be. /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif
In any case, I think I have the info I need to move on here. Thanks so much to everyone for sharing your knowledge and expertise. /forums/images/graemlins/grin.gif
   / In need of some engineering help #8
"HHCS = Hex Head Cap Screw.
1/2 NC X 6= 1/2-13 X 6" long. Grade 5"
DUH!!!! /forums/images/graemlins/blush.gif Then again, it's been awhile since I have called one or heard them called anything other than a freakin' bolt! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / In need of some engineering help #9
Could the "NC" refer to a National Coarse threaded bolt???
   / In need of some engineering help #10
That's what NC stands for, NF is National Fine. NC is also referred to as USS, NF is SAE.
METAL FILING CABINET (A53843)
METAL FILING...
2005 Freightliner M2 106 Box Truck (A52377)
2005 Freightliner...
2014 RAM 2500 (INOPERABLE) (A53843)
2014 RAM 2500...
2016 WESTERN STAR 4900 HYDROVAC (A53843)
2016 WESTERN STAR...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
