5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 26,997
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Back when I owned my 5030, I initiated a thread on this site concerning the modifications you could do to improve the airflow (negative) through the ac condenser and oil cooler.
Kubota places both the ac condensor and oil cooler (and ata units) fairly far from the main radiator core and fan. This creates a less than desireable air flow through the condenser and oil cooler(s) when the engine isn't turning rated rpm.
I eliminated the air space on my 5030 by placing rubber strips between the condenser and the radiator itself, effectively closing off the space between and creating a much more negative air flow pattern that resulted in better ac cooling and cooler HST temperatures.
Both my M9 and my 105 are configured similar but also have ata units to cool the intake air heated by turbocharging. While the ata unit is removed from the radiator itself, it still functions properly because the boost and elevated intake air temperature only comes into play at high load and higher rpm and the radiator fan can provide the needed airflow.
Not so with the ac condensor and the transmission cooler. They are both located lower down in the belly of the engine bay. There is little negative air flow at lower engine speeds. Consequently, the ac condensor and oil cooler loose efficiency resulting in less refrigerated air in the cab and to a lesser extent, elevated oil temperatures (not a big concern as both tractors are gear drive, not HST).
What I did, was mount a 12 volt slim profile radiator cooling fan in front of the ac condensor, wired through a 30 amp relay to the ac electromagnetic clutch so when the clutch is energized, the cooling fan is as well. I used a 7" diameter 1550 CFM unit (available on Flea-Bay) mounted to custom fabricated cross rails that span the framework that mounts the condensor and oil cooler. I mounted the fan behind the net that keeps the condensor/cooler assembly free of chaff.
Now, on hot days, the cab is cool if not cold at reduced rpm. I still need to clean the net a couple times a day in the field, but even with chaff on the net, the condensor is doing the job appreciably better than before.
I may get lazy at some point and istall a reversing switch so I can use the electric fan to blow off the net.
