Improvements You Need on PT
   / Improvements You Need on PT #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
Another can of worms. What improvements would you like on the PT that have not been discussed extensively on this site? Yes, new needs.
   / Improvements You Need on PT #2
I sense a think tank.
   / Improvements You Need on PT #3
I would like to see some sort of govening device on the joystick and treadle controls to prevent jerky movements. Sometimes these controls react like a hair-triger. When working with the very heavy attachment such as the snow blower I realy have to concentrate to achieve a slow movement of the FEL arm. A lot of times the heavy weight moves and stops too fast causing the heavy attachment to bounce which causes the whole tractor to begin bouncing. This is a scary situation. Also, sometimes I would like to have very fine movements similar to the inching capability on the Kubotas.
   / Improvements You Need on PT #4
You could install a thumb controlled solenoid diverter valve and divert the fluid through a restrictor for those slow operations you need. Switch off, hyd work normally. Switch on, the hyd operate in the slow mode.
You can also reduce engine rpm which will reduce flow. Will still have good pressure.
To slow the hyd manually, a pair of gate valve would route the fluid through a restrictor for slow operation, or one of these.
https://www.surpluscenter.com/item.asp?item=9-6133&catname=hydraulic
   / Improvements You Need on PT #5
Doubt you'll hear too many "new needs' since these machines have been discussed in depth...
Some things I'd like to see:
1. A float position on the lift arms that doesn't "bounce out of float" on rough terrain.... It needs to be "set and forget" similar to putting the 3-PT hitch down on a normal tractor. Doesn't need to be as complex and expensive as true draft control on the larger machines ...
2. Aux PTO controls up beside the steering wheel, rather than needing to do shadetree engineering to do that. A cable-operated control lever would probably cost less than $50 in additional parts, if installed when these things were built, and would require only VERY MINOR changes to the current design. The hydraulic circuits and control valves could remain where they are...
3. A stronger pivot joint between the two halves of the tractor. IMO this is the most stressed and potentially weakest link in the entire PT design...
4. Increased lift height on the smaller models -- even the "improved" 60" on the newer 425s is not enough. It needs to be 72" IMO.
5. Adaptor plates that would let you use mini-skid attachments on the smaller machines and skidsteer attachments on the larger ones -- while maintaining the PT advantage of hydraulic control over them, rather than manual pins/latches... (Never will happen from Tazewell, IMO, because they want to sell their proprietary designed attachments that are sized for only one class of machine).
6. True emergency/parking brake systems that activate automatically on the loss of hydraulic pressure... some wheel motors have this built-in, at an additional cost of less than $100 per wheel motor.
7. Wheel motors that are designed strong enough that reversing wheels or adding wheel weights or dual tires won't compromise the reliability...
8. Finish mower decks with a provision for adding a vacuum collector and bagging wagon...
9. Heavier duty rough-cut mowers...
10. Easy way to plumb in a control a rear hydraulic circuit for dump carts/wagons, etc.
11. Rear connectors for the main PTO circuit so you could power attachments off the rear of the machine, such as towed brush chippers, etc.
12. Published specs for hydraulic motors and pumps so it would be easier to size the motors required for custom attachments...
13. Factory provisions for ball hitch on the rear -- the current design only complicates things and serves little practical value. A plate that would support a 2" ball would likely cost less that what they currently use...
14. Adjustable forklifts for the smaller machines.
15. Post hole diggers that used common aftermarket augers instead of their proprietary design.
16. Male and female connectors on the AUX PTO circuit (similar to main PTO circuit) that prevents you from accidentally crossing the circuit for attachments. This wouldn't cost them anything extra, in the big scheme of things...
17. SAE-standard hydraulic quick connect fittings instead of these strange Italian connectors...
That's a quick brain-dump... I'm sure I could come up with quite a few more....
   / Improvements You Need on PT #6
Only 17 items. Is that all you got? :laughing:
Good list! :thumbsup:
   / Improvements You Need on PT #7
I installed some restriction valves that have worked great and are easy to adjust. I only installed two for the FEL arms, but it's easy enough to do for the other circuits too.
http://www.tractorbynet.com/forums/power-trac/49694-hydraulic-flow-restrictors.html
Phil
[on edit] in looking at that old thread, maybe I put the restrictors on the curl circuit. It's been SOOOO long and my memory isn't as good as it used to be, and it used to be pretty crappy. I put them in so I'd have better control of the stump grinder. I don't think I've messed with the restrictors since, things just work as I expect them to.
   / Improvements You Need on PT #8
I am assuming that reducing RPMs means easing back on the throttle? Also, is lift capacity and height affected by restricting flow or reducing RPMs?
   / Improvements You Need on PT #9
I am assuming that reducing RPM's means easing back on the throttle? Also, is lift capacity and height affected by restricting flow or reducing RPMs?
Yes on the throttle. Height and lift capacity is not affected.
Engine and pump speed affect the speed of operation.
   / Improvements You Need on PT #10
Thanks JJ, great suggestions.
Serco 270 Log Loader (A52384)
Serco 270 Log...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
2024 TOFT 1550 Hydraulic Breaker (A53117)
2024 TOFT 1550...
1pallet of miscellaneous items (A53117)
1pallet of...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Ford Tractor (A50120)
