canoetrpr
Veteran Member
- Joined
- Aug 7, 2005
- Messages
- 2,396
- Location
- Ontario, Canada
- Tractor
- Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
As I have acquired implements I have found that even the bottom pin widths are not uniform. Mine range from around 25" to about 28".
This is a tad irritating as it means that if I am switching from my snowblower to my bale spear or vice versa I have to get a wrench out and adjust the turn buckles (would be nice if my lower links had the pin style adjustment).
Do the rest of you have any tips on how you deal with this?
Things I have thought of:
- Pick up one of those stabilizer bars from Pats. Adjust the turnbuckles permanently down to 25" and put the stabilizer bar on to hold the arms into place at the right width for each implement I have.
- Look into modifying the implements so that they can all be the same width. This is a bit of a pain. Possible for some, much harder for others.
- Look into finding a replacement for my turn buckles with the pin type. Don't know if Kubota sells them as an option for my tractor or I would have to find parts from another model and see if they fit.
Right now I am thinking of going with the stablizer bar from Pats.
Any other ideas?
Any other ideas?
