Implements: Kubota vs Gearmore
   / Implements: Kubota vs Gearmore #1
HoggyB
Bronze Member
Hi, all-
I want to get an auger for my BX23.
The dealer is recommending a Gearmore over the Kubota as it is $300 cheaper. But, I think he said the Kubota was a heavier duty implement.
In general, what do you do? Go with the orange? Or aftermarket?
Hog
   / Implements: Kubota vs Gearmore #2
Gearmore is fine, especially for an auger. The thing that breaks on PHD is the shear pin, and it will do it a lot. Have extra bolts (shear pin) on hand. Auger at slow speeds and speed it up when done drilling to fling the dirt. A better auger bit will have better teeth for drilling in tougher ground. Hard pan can be almost impossible without some kind of power down and sharp teeth.
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
TMA (A49461)
TMA (A49461)
