Implement Storage
   / Implement Storage #1
judgeroybeanbag
Mahindra 3510
I am considering building a space other than my barn to park the tractor and store implements. Looking for creative ideas on storage - for example, my post hole digger and boom pole are currently chained to tree branches so I can hook them up myself. Has anyone found a good method for mounting them for easy hookup. I don't think hanging them from the rafters would be good as it puts too much weight on them.
Thanks in advance.
   / Implement Storage #2
This is what I use and it can be made as a dolly system if preferred and you have a concrete floor.:D Usually takes me less than 5 minutes for hookup.
   / Implement Storage
Thanks - that's more or less what I was looking for. I take it those are 4x4s. I could put them at one end of the shed, set in concrete.
   / Implement Storage #4
Yep, 4x4s, a couple Simpson hangers, no concrete required. Hookup, lift up, remove top 4x4, drive away and go to work. Simple, simple, simple. I set my posts 30" deep, in 6" holes that I drilled with the auger.:D Have had no problems so far.;) What I need to do is build something to hold all my bits.
   / Implement Storage #5
Hey Brian!
Is that a hyd cylinder on your phd? How does it work
Hey Judgeroybeanbag you a Texan?
   / Implement Storage #6
digicamnut said:
Hey Brian!
quote]
Yes, I have a Land Pride PD35 post hole digger with the Land Pride hydraulic down pressure kit. Don't know how well it works yet, have not used it with the down pressure kit installed yet. I imagine with over 5000lbs of pressure it should drill anything that I need to put a hole in.
   / Implement Storage #7
Like you, my PHD spends it's life hanging from a tree limb. If you do a search on here there was a great thread on PHD stands quite some time back. I stole one of the ideas and build a PHD stand for my S-I-L at the farm. It was basically a gallows with the PHD hanging on a chain hoist. The square base had wheels on it so you could move it around for ease of mounting. I also built a couple of steps on it so my S-I-L could climb up it if necessary - she's a smurf but she's a 5' tall tractor riding son of a gun. :)
   / Implement Storage #8
Judge,
We have an infestation of fake new members here. I doubt your question has anything to do with rafters. If you hang anything from rafters for real, I'd be happy to help you with the carpentry aspect, and the site is also overpopulated with engineers. Enjoy, whoever you are. Jake
   / Implement Storage #9
jake98 said:
Judge,
Just what is your problem Jake?
   / Implement Storage #10
I'd like to edit my comment out of here but the edit feature seems to have gone missing. Apologies for my suspicious nature, Judge Roy.
Jake
jake98 said:
Judge,
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
2019 Allmand Bros Maxi-Lite II S/A Towable Light (A52377)
2019 Allmand Bros...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
