Implement shed on an incline
   / Implement shed on an incline #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
After years of parking my tractor under the tree - and tarp - with implements all around it, I decided to put up a simple shelter to protect it all. The place for it is on an incline, maybe 5 degrees. I should still build it with the roof horizontal when looking from the front, right? The roof will be sloped front to back of course but right to left it should not follow the terrain? I am not sure where it popped from in my head, maybe from the fence I built?
   / Implement shed on an incline #2
If you have a box blade i would try to level the spot asmuch as possible. but yes i would make the roofline level.
   / Implement shed on an incline #3
Is this a pre-fab shed being built by a shed company and delivered? Or being built on site?
If built on site or delivered, try to level the ground. If being delivered, another option is to place 6x6 ties on the low side or end to level the shed, like a giant shim.
   / Implement shed on an incline #4
Do what ever it takes to make the building plumb and level. It will look so much better.
   / Implement shed on an incline #5
AND it will be easier to maintain, and the rain runs down hill, so if your roof slopes front to back and it slopes side to side, the rain will run diagonally across your roof.
   / Implement shed on an incline #6
Regardless of your terrain, gravity works vertically. If you build off plumb, in a few years it will be a lot farther off plumb.
   / Implement shed on an incline #8
You right but get some string and a string level (cheap) and get your foundation eyeballed ,you don't have to level the foundation / earth just some post will be longer than others but if the idea is following the slope of your land I say go for it, 5% grade is hardly worth worrying about in something like this. Long as the sides and roof are square and sloped as you want, six inch pitch would be fine for such a cover. Hope it goes well. Yeah don't follow the terrain ,string level should give you the measurement you desire, run from ground level on the high end and drive a stake, pipe, 2x2, etc on the low end and level and tie off then you measure the low end distance from ground to string level that's the extra deepness and longer post you'll need.
   / Implement shed on an incline #9
By building plumb and level, the weight is placed to bear directly down on the walls and posts. Any angles causes that weight to push “sideways” along with down. This puts stress on every joint and fastener trying to hold it together.
As the wood dries out these all loosen making the structure lean more over time.
And it looks better!
Thanks!
I am slowly working on it, milling every piece of lumber, there is no way I am going to pay $50 for a bloody 6x6 - 8' beam.
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
1989 14ft. Gamefisher Aluminum Jon Boat with Trailer (A51694)
1989 14ft...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2016 Case IH True Tandem 345 (A50123)
2016 Case IH True...
2008 New Holland B110 MFWD Loader Backhoe (A53473)
2008 New Holland...
2005 INTERNATIONAL4300 WRECKER (A53426)
2005...
