IMatch question
   / IMatch question #1
rioravioli
VT
JD 2305
IMatch question -
Couldn't find this in any of the documentation - so I must ask others:
For those that know, should I level my IMatch / 3 point - in the extreme up position or the extreme down position just hovering above the ground, have ballast box attached ... thx
   / IMatch question #2
You will want the iMatch hitch to be vertical when the 3 point hitch is in the lowered position. This is the position when you are back up to and picking up your attachments. This assumes that the attachment has been parked on the same plane as where the tractor will be when picking it up. The iMatch works easiest when the attachment has been parked on a firm level surface and the tractor also will be level when approaching it. If this is not the case, some adjusting of the 3 point links may be required.
   / IMatch question #3
Assuming a flat parking space you want it level when just off the ground.
I think you will find that adding a hydraulic top link is going to make using the I Match much easier. Not a whole lot of point in having it if you have to get off the tractor to adjust the top link. I use it with top and tilt and it is very convienient.
Steve
   / IMatch question
Hydraulic top link, now that's the ticket - thx, for the advice - see another reason why I can't get banned -
   / IMatch question
I'm assuming this will work with a 2305...?
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2018 John Deere 470G Hydraulic Excavator (A55787)
2018 John Deere...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2014 MACK ELITE...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
