Tractor Sizing I'm a newbie
   / I'm a newbie #1
Oiltech
La
Kubota L3540HSTC, M7060HDC-12, ZD331-72, Bobcat E42
First post and a question. Just purchased 12.5 acres of flat land that has 50 fifty year old live oaks. I don't want to spend all of my time cutting grass but do enjoy the private time doing so, sort of like therapy and its all the better if inside an air conditioned cab. I currently have a Kubota L3540 with 160 hours. This machine has FEL, fork lift attachment, 72" box blade and 60" tiller.
I am thinking a 70-80 HP tractor with 15' bat wing for the large open areas and a 84" grooming mower for around the trees, home and toy box to be pulled with the Kubota.
Please offer me y'all's opinion on which tractor, batwing, grooming mower or if there is a better way to keep the grass cut:)
   / I'm a newbie #2
Welcome to TBN, Get a pack of Goats.
   / I'm a newbie #3
So let me get this right you enjoy relaxing for the hour that it takes to cut your grass. Get a 7 foot zero turn and run 13 miles ahour. You will not have time to sweat.
   / I'm a newbie #4
Welcome from NW Florida. If mowing is your biggest job, save your money and add a 6' RFM and a 6' Bush Hog to the L3540. At 160 hours it is just getting broke in. I mow 6 1/2 acres with a RFM and with the trees I have, anything bigger than 6' would be PITA. I still have to trim around the trees with a smaller mower on my B7500 or use one of the riders.
   / I'm a newbie #5
I don't see the need for a 70 to 80 hp tractor, a better choice would be the Kubota L5740 HSTC cab or the Deere 4520 cab both are 60 hp. Good manueverability with a hydro tranny and would match up well to an eight ft semi mount brush mower. I would use a zero turn to mow around the house and trees.
There are lots of other brands to choose from that would work well, just depends on what is available in your area.
   / I'm a newbie #6
Okay, I'm confused. Do you have 50 trees that are 1 year old or do you have many trees that are 50 years old? If the latter and you are mowing around 50 yr-old trees, then how high are the tree limbs. Liveoaks can have a huge canopy that could wreak havoc with a tractor's cab. I would think a small tractor with cab would be far better than a larger tractor for all the turns and to make sure the cab doesn't get damaged under the trees.
   / I'm a newbie #7
Welcome.
That so much more overkill than I've ever seen! I'm using a L3800DT on 400 acres. :eek:
   / I'm a newbie #8
Thanks Jinman for the question. I took it as several 50 year old trees, thus my suggestion of sticking with the smaller tractor. If it was fifty trees that are one year old, the larger tractor would work. {I still think it would be overkill for lot size}
Not a live oak, but about fifteen to twenty years old. Even if the trees are one year old, oaks grow like crazy.
   / I'm a newbie #9
He said he'd use the cab tractor with the batwing in the open areas, and a smaller RFM behind the current L3540....makes sense.
My only thoughts are that 70-80hp tractors and 15' batwings are going to be pricey, and it sounds like overkill for that much land. But hey, if he can afford it, the economy can use folks buying expensive stuff, and it certainly will save him some time!
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2008 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2008 CATERPILLAR...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
1996 International Bucket Truck (A50323)
1996 International...
6-Row Narrow Cultivator (A52128)
6-Row Narrow...
