IH460 Diesel Leaking hyd fluid
   / IH460 Diesel Leaking hyd fluid #1
ih460ut
international/IH460 Deisel
I have a 1959 IH460 diesel utilty tractor and after 40 minutes it starts leaking hyd fluid out of the top of the steering column. I replaced the seal at the top of the column but still leaks till it blows the seal out. I checked the fluid and it's where it should be.Any help would be great.
   / IH460 Diesel Leaking hyd fluid #2
Check for very small air bubbles in the oil when it s overflowing? Its called airation of the oil.
Check for a leak of air into the sisteme (hoseclamps or cracked hoses)
No air bubbles it's building up way to much pressure
2025 CFG Industrial KKT(A)27 (A50123)
2025 CFG...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2007 Mercedes-Benz S550 AWD Sedan (A51694)
2007 Mercedes-Benz...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
