IH SMD single to dual Hydraulic conversion w/ behlen power steering
   / IH SMD single to dual Hydraulic conversion w/ behlen power steering #1
Mitch Ernst
IH SMD
Hi, I attempted to convert my SMD with single hydraulics to a dual hydrulic (christmas tree)configuration. The tractor has a Behlen power steering unit run off the tractors haudraulic system (worked fine originally). I plumbed the pressure side of hydraulics to power steering then T'ed off to inlet for dual valve. Nothing works now! Is this because I have two center system hydraulic units in tandem or something? I'm Lost! And my IH Case shop is too. Is some other valve needed? The Charlynn PS systems run directly off the engine so wouldn't conflict. Need some help from the wise and experienced!!!
2016 Case IH True Tandem 345 (A50123)
2016 Case IH True...
2019 Bobcat E32i Mini Excavator (A51691)
2019 Bobcat E32i...
2016 Suzuki King Quad 500AXI 4x4 ATV (A51694)
2016 Suzuki King...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51691)
2017 Mack GU713...
Kubota SVL95-2 High Flow Cab Skid Steer (A53473)
Kubota SVL95-2...
Ryno Worx Sealant Applicator and sealant pots (A52384)
Ryno Worx Sealant...
