IH hard starting
   / IH hard starting #1
petebacsr
massey fergusn mf65
New to IH need help. I have a model F656D HS diesel I have to use ether to start it hot or cold. There is smoke coming out of the exhaust but it just won't start. Any suggestions on what to check for.
   / IH hard starting #2
I would buy a compression tester and see what that is like. That's typically a good place to start with an issue like that.
Tractors can kinda become addicted to ether. Once they are started on them, they won't go back to the old way
   / IH hard starting #3
The IH 282 diesel engine is an indirect injection diesel. It has a glow plug in each cylinder's pre-combustion chamber, and the glow plugs and wiring need to be up to snuff and used for every start, year around. If you are using ether instead of the glow plugs, you will damage the engine. Not if, but when. This engine will not tolerate a steady diet of ether.
Best advise I can give is fix it if necessary, learn how to start it properly, or sell it before you trash the engine.
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A52576)
1968 CHEVROLET C10...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
