IH equivalent of JD 3020
   / IH equivalent of JD 3020 #1
bocephus
can you tell me the equivalent in IH of a Deere 3020 or 4020?
thanks
   / IH equivalent of JD 3020 #2
A 706 would be pretty close 3020. The 706 was 70HP were as the 3020 was 65HP to the best of my knowledge. The 806 would be close to a 4020 since they are both 80 horse tractors. The Internationals had several advantages over the John Deeres. They were a heavier tractor and also would use less fuel. They also had and optional "Torque Amplifier" that would give you a slightly lower hydraulically shifted gear in each mechanical gear.
   / IH equivalent of JD 3020 #3
After the 806, the 856, and the late 4020 were built at the same time. untill 1971, 72 I think.
Chuck
   / IH equivalent of JD 3020 #4
i would say either the 706 or 656 is pretty close to the 3020 and maybe the 800 or 900 series are closer to the 4020 90hp
   / IH equivalent of JD 3020 #5
thanks
IH answered Deere's 4010 with the 806. Deere responded with the 4020. IH countered with the 856.
Deere's 3010 was matched by the 606. Deere came back with the 3020 The IH 706 was just a tad bigger than the 3020. Deere responded to the 706 with their 4000. It had the same engine as the 4020 and was more HP than the 706.
   / IH equivalent of JD 3020 #6
The 606, 706 and 806 were all offered in the summer of 1963. The 606 was a utility model, the 706 had 73 PTO horsepower and the 806 94 PTO horsepower.
   / IH equivalent of JD 3020 #7
I always put the 3020 and the 4020 with the 706 and 806 although the red given all things equal ate the deeres for lunch while at the fuel tank getting refilled. The deeres never could pull the hills well between lower torque rises and the constant ballast changes between full tank of fuel and empty they were touchy as to when you could do what you might need to do. We had 706's pulling four and five bottom plows here and the 3020 at best was a slow four and most 4020's just pulled four.
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
CAT MINI EXCAVATOR 303C (A50854)
CAT MINI EXCAVATOR...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
Danuser Digger F-8 (A51039)
Danuser Digger F-8...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
