IH B2275 fluids
   / IH B2275 fluids #1
vedur
Estonia, Northern Europe
1983 T-40AM
Hello!
I recently acquired an International Harvester B2275 loader-backhoe of unknown manufacturing year (S/N: 800). Due to age many of the hydraulic lines have deteriorated and need to be replaced. I have already drained the hydraulic fluid and I'm getting the custom made hoses tomorrow. I want to refill the system with fresh fluid as well but I am unable to find any information about the fluid my machine takes. I do have the service manual for a B275 on which my B2275 is based on and it says that hydraulic system should be filled with HyTran fluid. Unfortunately I have no Case or New Holland dealerships within an hours drive from my home. I have done some research and found that Low Temp HyTran (which I want because the loader will be used in the winter) is roughly equivalent to ISO 32 hydraulic fluid (or SAE 10W engine oil). I do have an industrial chemicals supplier near me who does have ISO 32 HLP and HLVP oils in stock and the price is acceptable. The old fluid was pinkish-red.
Is ISO 32 HLP oil a good substitute for Low Temp HyTran?
Also, I would like to replace oil in the transmission too and it also calls for HyTran but I am a bit skeptical about using hydraulic oil in a transmission but then again I have had manual transmission cars that have called for ATF instead... Is hydraulic oil acceptable in a transmission?
Utility Trailer (A42742)
Utility Trailer...
2008 WELLS CARGO 16’ T/A ENCLOSED TRAILER (A45046)
2008 WELLS CARGO...
2012 Dodge Charger Sedan (A42744)
2012 Dodge Charger...
10'x20' Single Garage Metal Shed (A44502)
10'x20' Single...
1965 Correct Craft Wildcat Boat and Trailer (A44391)
1965 Correct Craft...
2016 Chevrolet Silverado 2500 HD (A44501)
2016 Chevrolet...
