rectifier
Bronze Member
- Joined
- May 8, 2015
- Messages
- 57
- Location
- Saskatchewan, Canada
- Tractor
- Deutz DX160, IH B-275, Z225 zero-turn
Had a pair of glows fail on me. I have a set of new 12V Bosch to replace them.
I managed to recover the burnt out piece of one via shop vac. The other... I could see the edge of it, but on attempt to seize it with needle-nose pliers, it dropped back and down, probably about 1/4", somewhere inside what I assume is the precombustion chamber.
The intake valve for this cylinder is closed but I've pulled the injector, valve cover and intake manifold and still can't determine whether it could have dropped into the cylinder or if it will be held back by the valve. I assume that as the diesel is injected into the chamber in question, it is inside the valves and the piece could have fallen right into the cylinder. However I've never had the heads off this machine so don't know exactly what is in there.
So... any ideas to recover it other than pulling the heads off? That's a lot of work for a tiny piece of crap
This is our winter chore tractor and we're going to be rolling round bales by hand until it's fixed, not much fun.
