IH 784 Hydraulics...
/ IH 784 Hydraulics... #1
polyfusion
Ireland
IH784 MF135
Trying to understand a bit more about our hydraulics, and put them to the best use.
We have a 784 which has two Kontak spool valves, and two levers on the right hand side of the seat for operating them. The 784 has a simple front end loader, just up (hydraulic pressure) and down (gravity assist) (front end is released with a cable). One of the valves has one pipe coming out of it, and the other has two pipes. All pipes terminate at the back of the tractor with screw-on type connectors. The single pipe going to the FEL is connected to the valve with two pipes coming from it.
Since we got the tractor and FEL, probably more than 20 years ago, the two levers were stuck, but we recently took the linkage apart and freed it up. We might be looking to add more functionality to the FEL, and/or get other hydraulic implements to better use the hydraulics.
One thing we noticed is that the double-acting valve to which the FEL is attached will always return to the neutral position when you let go of the controlling lever. The other lever that controls the single acting valve locks in the up or down positions when moved to those positions, and you have to physically move the lever to the neutral position to stop the pumping.
Would we be better off with the simple FEL connected to the single-acting valve?
Also, would the single acting valve have a float position? The linkage is quite worn, and the lever is at as far down as it can go when in the down position, on the floor, so difficult to see if it can go down further than the down position.
No, it's a simple FEL (Quicke 2200E), just one pipe going to it to lift the arms. I presume that when the lever is put to down, the weight of the FEL forces the hydraulic oil back through the valve into the sump.
No piston at the front end to curl the attachment. This is something we might like to add, like for a bucket, for example.
/ IH 784 Hydraulics... #4
one lever is springoperated end the other one is detent operated .
It can be change to both spring operated to help with operating the FEL
Can either of these valves be used to supply a valvebank on something like a hedgecutter or a round bale wrapper?
/ IH 784 Hydraulics... #6
I beliefe so....detent operating one to that valvebank....make sure of direction of flow...do not put valve in float...then nothing will happen
/ IH 784 Hydraulics... #7
I would be interested in seeing pics of your tractor and loader,,
it would assist in answering your questions,,,
This is my 584
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
NO ADDITIONAL ONLINE BUYERS PREMIUM ON BID.FIVESTARAUCTION.COM (A64047)
NO ADDITIONAL...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
