IH 75C Oil drain plugs
   / IH 75C Oil drain plugs #1
dcast10
Denville, NJ
2014 Case 75C, AGT H15, Bolens G274
Need to change the engine oil on my "new" 2014 75C. What size allen wrench do I need to get the drain plugs out? Seems to be 7/16 or maybe 11 or 12 mm. Of course my set only goes to 3/8 and 10mm.
The drain plugs take a 12mm hex head. I will have to see if I can find a bolt with a 12mm head and some nuts to make an adapter. If not, I know I have a punch with that size shaft I can cut down.
Case 580D (A47384)
Case 580D (A47384)
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
3 1/2 BLACK CONDUIT WITH ROLL OF FABRIC INNERDUCT (A50854)
3 1/2 BLACK...
WEATHERFORD TRIPLEX PUMP WITH ELECTRICAL PANELS (A50854)
WEATHERFORD...
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
