Cowpaddy52
1st. time on here , I'm sure someone has run across this before . I'm stumped we have a 706D tractor with NO BRAKES the power steering and torque amplifier work fine. I've changed the hyd. filter refilled the oil level to full, then added 3 gallon. The right brake was weak at the end of hay season last year, left side was working fine . It's been a while since I've worked on this model and was wondering if anyone could give some insight as to what could be causing the problem and a possible solution. Thanks in advance for any help.
d
f farmall
d
f farmall
