Oil & Fuel IH 574 fuel injection problem....
/ IH 574 fuel injection problem.... #1
Roger3rd
I have an IH 574 diesel tractor that starts right up and idles fine, but when I try to accelerate, it dies. Was told it has a broken throttle shaft, but not sure. Don't want to remove injector pump until I know more. Anyone face this problem and have any advise? thanks, Roger
/ IH 574 fuel injection problem.... #2
Mine has the same problem. It will run slow and just above idel but when you advance the throtal it pops and then dies. I was told it was a fuel problem,trash in the tank or sucking air at the filters. I havent had time to check this out. Trying to finish the shop.
/ IH 574 fuel injection problem.... #4
If you'll 100% sure that your tank is clean (free of rust, dirt, etc.) and your filters are clean, you may have a problem with your injection pump. Hope this helps.
/ IH 574 fuel injection problem.... #5
I got to thinking about your problem and I remembered that my tractor has died on me as I was trying to increase the throttle a couple of times. I remembered that the governor hadn't opened up. Could be that the governor is sticking or that it is getting worn or out of adjustment.
