IH 464, Deere 1250, or Ford 4610 - which to buy
   / IH 464, Deere 1250, or Ford 4610 - which to buy #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
I am looking at three tractors to mow about 60 acres with a brush hog. A Ford 4610 3.3 liter diesel with 1800 hours for $4800, a Deere 1250 2.3 liter diesel with 5500 hours for $4000, or a International 464 with 2.9 liter gas and 1300 hours for $3000. All have gear transmissions. I am leaning towards the Ford because of the power, roll bar that the IH does not have, better shock absorbing seat, and low hours. I would appreciate opinions, especially on how much life I should get on the engines. Thanks.
   / IH 464, Deere 1250, or Ford 4610 - which to buy #2
The Ford is an easy choice. More HP, Better features, FAR better OEM AND aftermarket parts availability. Ignition and fuel system parts for the IH will be difficult to find; stay away from that. 50 series Deere CUT parts are spendy and increasingly difficult to find; the 1250 and 1650 had lower production numbers than the 850 and 950 so the problem is worse with the larger models.
   / IH 464, Deere 1250, or Ford 4610 - which to buy #3
Out of the list you have the 4610. If the 464 was diesel I'd consider it. 4610 is a newer tractor anyways.
1250 Deere is a Yanmar.
   / IH 464, Deere 1250, or Ford 4610 - which to buy #4
The IH 464 came in gas or diesel.
If it is diesel, it might be a good buy.
I have 2 IH tractors and they work good for me and I have not had a problem finding parts.
   / IH 464, Deere 1250, or Ford 4610 - which to buy #5
OP clearly says the 464 is a gasser. I'll stand by my comments relating to that configuration.
   / IH 464, Deere 1250, or Ford 4610 - which to buy #6
I'm a diehard IH guy, but in your situation you need the Ford. Diesel, more power, and more comfortable.
Might I suggest an even larger tractor? 60 acres is ALLOT of land to bushog with a 50HP tractor and 6' bushog.
   / IH 464, Deere 1250, or Ford 4610 - which to buy #7
Depending on what is actually being cut, a 7 or 8 foot cutter may be in order.
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A53472)
2015 Ottawa Yard...
