IH 354 utility tractor
   / IH 354 utility tractor #1
diyDave
A friend just got a IH 354 gas tractor. I think its a British import, about 28 dbhp, 34 bhp, heavy little cuss, the tranny looks a lot like the B-275, a bathtub full of gears. Does anyone know how many of these were imported in the early '70's? Any guess at a value for one in good shape?:confused: :confused:
   / IH 354 utility tractor #3
We have the same model. Around here in WV they run from high $3000 to high $4000 dollar range. Ours has been very reliable except the brakes lock up occasionally (just run in reverse a foot or so and they unlock) and the Disributor cap collect water on occassion (maybe once a year). They are pretty common tractors.
Rich
   / IH 354 utility tractor #4
The brakes a simple and you should take them apart and clean the actuators so the balls roll better in the ramps. Your springs being weak might also cause the problem. They are quite simple to work on!
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHHL8161 (A51572)
2016 Freightliner...
