IH 3414 final drive gasket
   / IH 3414 final drive gasket #1
Fallguy1000
JD
I need to replace/repair the final drive gasket for my IH 3414.
I called Komatsu and they didn't really follow up with me. Do I need to badger Komatsu, or is there another place I can go, or can I build one as good for less $$$?
Thanks in advance. Dan
   / IH 3414 final drive gasket #2
Do you have a parts manual? If you have the parts manual, you can do a search with that part number through a search engine. I have had my best luck using Google.
If you don't have one, there are several on ebay, one is right at $20.00. A good investment, if you are planning on keeping it.
I have read in other threads/forums, where the 3414 is based on the IH
B414, engine, and some chassis. Those parts are searchable through Case/IH parts Case IH Agriculture & Farm Equipment
Maybe down in the Construction section someone may be able to help you, that may have a manual.
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
