IH 3414 carb
   / IH 3414 carb #1
louie769
voluntown, ct
3414/3418 ih
i have a 3414 gas motor ,.i am looking for info in what carb is supposed to be on it. the one i have is too small and it wont run right. anyone with info would be a great help
   / IH 3414 carb #2
That should have the BC-144 gas engine. Here is a link, through Messick's of the BC-144 engine: (BC-144) - 4 CYL. LP & GAS ENGINE There were two carbs. used, and the engine serial number break is listed at the top of the page, just above the exploded view of the carb. that appears. Hopefully it is the original, and maybe needs a kit, as new carbs are rather pricey..!! If that isn't the right carb, by serial number, select the other one in the menu at the left side of the page.
Write down the part #'s and do a Google search. Mostly kits listed in the results, but look further a couple of pages, and you'll find the carbs listed. What I found, are right at $535.00.
Hope this helps...
   / IH 3414 carb
thanks i will look and see what i can find.. maybe i can fit a different kind on it. but it may help
71065 (A49346)
71065 (A49346)
2017 Nissan Murano SUV (A50324)
2017 Nissan Murano...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
2013 MACK GU713 (A50854)
2013 MACK GU713...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2014 GOOSENECK DRIVER SIMULATOR TRAILER (A50854)
2014 GOOSENECK...
