IH 295 Planters
   / IH 295 Planters #1
acobb
Mid GA
04 JD 5420
I am purchasing a set of 4 row IH 295 planters on a heavy Pittsburg (I think)
cultivator frame. The seller has not provided the age as of yet but I think it is at least 20 years old. Anyone have any idea what this setup would cost when it was new?
   / IH 295 Planters #2
I would have to say the 295 planter units are more then twenty years old! They were used around in the sixties!!!
I hope you aren't going to do a lot of acreage as the runner openers can be a bit expensive if still available. Depending on soil you might get about twenty acres to a row as far as wear.
They were a good placement unit but the plates do cause some problems today as well graded seed like they used years ago can not be found although with a little patience it will work.
   / IH 295 Planters #3
Actually, the IH 295 planter units were first produced starting in January of 1969 and continued to be in production for quit some time. Some small changes were made throughout their production years. Most if not nearly all were double disc opener type units and will plant many thousand acres without major investment for parts. The bearings in the double disc openers will eventually fail but can be replaced without buying the whole disc if you remove six rivets.
The JD 71 flex units were much more popular, but, I preferred the IH 295. Most sellers on the net seem to want about $295 for each unit. I'm sorry but I don't know their original cost. At $295 they better be pristine, notably no cracks in the casting members, the fiberglass buckets in good condition, gears not excessively worn (there should not be too much play), lids fit well and are not cracked, double disc diameter large enough to plant at correct depth, are the seed tube in good condition, etc. Depending on the crop you want to plant, do they have the correct depth bands?
If they are in good condition they will do a very good job at a reasonable cost.
Quit a few sellers of seed plates (mostly used) are on the net. If you need new plates they can be obtained from: Lincoln Ag Products
They are located in Lincoln, NE. I am located in the same state but am near Wyoming in the Panhandle. Plates are not cheap, but neither are the JD plates.
Good luck,
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
378801 (A51572)
378801 (A51572)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
