IH 284 Hydraulic Pump Noisy, No Lift in 3Pt Hitch - best repair approach?
   / IH 284 Hydraulic Pump Noisy, No Lift in 3Pt Hitch - best repair approach? #1
JECarterII
West Liberty
IH 284
Long time reader, first time poster. I have a 1973-ish IH 284, gas 2WD with a 3 pt hitch. The hydraulic pump sits behind the front grill and is directly powered by the engine crank shaft.
Tonight, I lifted my 3 pt mower deck and the pump made a horrendous screech that I have not heard before. It held the deck in the up position until I let it down to mow for a while and then I tried to raise it to make a turn and I had nothing in the lever, no pump noise, no lift, nothing. After a bit, I started noticing a squeaking noise coming from the motor somewhere and put it in N and hopped off to investigate (after stopping and disengaging the PTO).
The noise is clearly coming from the pump and I fear it's shot. While I begin my search for a replacement, I wondered if anyone could comment on the best way to repair it.
I took the front grill off and notice that the two metal lines coming into the pump have many bolts attaching them that look undisturbed since manufacture. The front of the pump, though, has a few bolts that look like they have seen some work. It looks like the pump front cover can be removed, I'm wondering if that means it can be serviced without removing it altogether - because that looks like one heck of a nasty job.
To get to any of that, though, I think the hood needs to come off the frame. There are two large bolts inside the front cowl behind the grill, and three to five where it joins the instrument console. I'll have to remove the "muffler" and gas cap but I think that's all there is to removing it. From there, all of the bolts on the pump are more accessible but I'm hoping just disassembling the pump and maybe pulling and replacing an impeller is all that is needed.
Thoughts?
Best regards,
JE
   / IH 284 Hydraulic Pump Noisy, No Lift in 3Pt Hitch - best repair approach? #2
I have a MF with a front pump like yours, and it was making an awful noise. Turns out it was simply low on hydraulic oil and was struggling.
Thanks, brookmere. I thought to check that and should have mentioned - I pulled the cap on the reservoir under the driver's seat and it is full to the top.
I found the parts diagram at IHCase's website: Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts
I suspect from the noise that one of those two shafts is broken. But, the hydraulic line filter is so old the writing is all faded on it. Maybe I should start by replacing that?
Also, when you say it was struggling, did you have any power at all in the hydraulic system? It seems like I've got no flow at all.
Thanks!
   / IH 284 Hydraulic Pump Noisy, No Lift in 3Pt Hitch - best repair approach? #4
Yes I had power, but noisy and not easy to control. Maybe bypass the filter, or remove it to see if there is a difference? Good luck.
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
