IH 215 Plow questions
   / IH 215 Plow questions #1
Ramon
NC
Farmall 100
Couple of questions...
1. Does anyone of have closeup pictures of the colter set up on a 215 plow. Wengers.com has some good general photos but I need some close-ups so I can make sure I have everything in the correct place for both front and rear colters.
2. At the bottom of the plows, near the landslides, the is a little diagonal arrow on a one inch metal square. On an older plow with the original stickers on it, it mentioned that this was some sort of adjustment. What type of adjustment is it?
3. In the event the plow actually trips, how do you put it back in normal position?
Ramon
   / IH 215 Plow questions #2
Hello Ramon,
Its been a long time, but the old IH plows we had were either shear blot or spring trip.
The shear bolt standards took some time to reset [depending on how tired you were to hammer out the broken shear bolt and replace it], but the spring trip would reset by backing the tractor with the plow still in the ground.
phil
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2009 MACK CXU613 DAYCAB (A50854)
2009 MACK CXU613...
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
