IH 1586
   / IH 1586 #1
cat2
Bronze Member
Hey, How do you turn the injector pump up to get more power?
   / IH 1586 #2
Four screws on the top of the injection pump I believe they are 7/16th and when removed you should see a screw with a lock nut laying down. Just start removing the screw. It will do you no good to remove it as a stock injector pump will only supply fuel to about 225 horsepower.
I can't tell you that a turn will give you twenty horsepower or five as for all that I've played with them I have had no consistancy with them. I do totally recommend having a dnyo when doing it to initially check to see what it is and to check when done.
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
Scag Mower (A50324)
Scag Mower (A50324)
1270 (A50490)
1270 (A50490)
378786 (A51573)
378786 (A51573)
378713 (A51573)
378713 (A51573)
