Ignorant electrical problem
   / Ignorant electrical problem #1
The dirt doctor
Bx 2350
My father has a L4630. He is having a problem with it shutting off. We changed out the fuel cut off solenoid and that seemed to fix it for a bit, but now the problem is coming back. Anyone have issues like this?
   / Ignorant electrical problem #2
Tractor newbie so just a guess here. Try disconnection the seat "shut-off" safety switch just to see if that is the issue. I've seen many motorcycles whereas the kickstand safety switch malfunctioned causing the bike to shut down.
Tried that. The tractor could be idling for minutes and all of the sudden start clicking and shut off..
   / Ignorant electrical problem #4
The same clicking the fuel pump makes before starting?
Yeah. The solenoid clicks
   / Ignorant electrical problem #6
I'm guessing that the clicking is the power going to the solenoid. I think you'll need to get a wiring diagram of the circuit and find where the power comes from and what it goes through. With a multimeter or test light you can check to see where the power is getting cut off. You may also want to check all the connectors, maybe a stick hit one and it's not fully connected.
   / Ignorant electrical problem #7
Did some searching; best I can find of those with similar issues is that it may be the Start Relay Switch rather than the Stop Solenoid.
mjw357 said:
By shutting off, do you mean the motor is quitting, or is it losing all electrical power?
It's quitting
   / Ignorant electrical problem #10
If it's wired similar to my M4900 I would suspect a faulty engine oil sending unit. I installed an electric fuel pump on my M4900 and the fuel pump runs after engine is shut off until oil pressure drops,then it stops. I wired the elect. fuel pump to wire that supplies inj pump. I had noticed that before elect fuel pump installation that when stopping engine I could here the fuel solenoid on Inj pump click while I was exiting tractor.
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
UNUSED MOWER KING 72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
