Gem99ultra
Elite Member
Well little Husqvarna Rider 155 ('02 model year with >2500 mowing hours) finally went down. It didn稚 actually totally go down, but I noticed that it was a lot louder when I engaged the blades. So I decided to investigate the problem.
I found two of the three spindles making bearing noise. Tore them apart and found one spindle bearing totally shot, and another with a slight noise. So, I致e order two spindles @ $59 each. I HOPE the assembly is totally complete, i.e. the top section and the bottom section. I can稚 really tell from diagrams what痴 included. Guess I値l know in a couple of weeks. And, if the assembly doesn稚 include both sections I only HOPE that the missing portion is still available.
What cost me money is that I discovered that 鉄EALED bearings CAN be greased. The rubber covering can be picked up with a pin and the bearing repacked. Needless to say, I致e repacked the idlers and the third spindle bearings, and will also pack the new ones with marine grade grease when I get them. IF I壇 only known, I could have saved about $120 bucks or more. Ignorance cost money.
