hotwired
Please dont shoot me for posting this.Have had misfortune to work on and around 4 cyl many years ? have found that when timing was changed due to broken distributor or shaft or gears and the factory timing changed have seen wisc mechanics do their thing timing light etc etc they always got engines running but not like before timing was altered, most machines that have 4 cyl will run and operate out of time but due to raw fuel going into cylinders and not ignited causes cylinders to wear out before they should,my ? is any sure fire way to time an engine,I once saw an old shade tree mechanic that would only way to time an engine properly he would take cylinder head off and then set timing he claimed this is only way to time an engine due to wear in gears and shafts.if you examine the timing procedure on the manuals the engine will run but not be timed right.Any one have any pros or cons on this.
