Ignition switch problem
   / Ignition switch problem #1
wklemm
Bryan, Texas
MF TO35
I have a TO35 in which the ignition switch went bad. I got a new universal switch, and it only works if I hold key in start position for several seconds and jiggle the sterring wheel back and forth very hard. Then I got an AI Products switch (883928M91) switch just for MF. It didn't work at all (a tractor mechanic said this switch only works on diesel TO354s (mine is gas), despite the mfg. claim that it works for both. Then I got another 3-pin switch that an on-line tractor dealer said would work on gas TO35. It doesn't work either.
None of the switches tell you how to hook up. Using an ohmeter, I thing I found the pin on each one that gets the + connection. Switch positions (2-4) show continuity with the single pole + connection, and I take a lead from one of the switch position contacts to the coil. Can anybody help with this problem?
   / Ignition switch problem #2
The TO35 didn't have a all-in-one switch, see pages uploaded, but if yours has been fitted out different then the first turn of the key will be the ignition on (battery to coil) and the next turn will be the start (feed to starter solenoid).
  • T0MF35_F40_MHMF_50_MF_65_12V.pdf
  • TO_30_12V_Continetal_gas_generator.pdf
Wow! Thank you so much. I had not been able to find even a tractor dealer who knew how to get this wiring diagram.
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2020 JOHN DEERE CP690 LOT IDENTIFIER 254 (A53084)
2020 JOHN DEERE...
UNUSED RAYTREE RTSG30-30" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2016 Case IH True Tandem 345 (A50123)
2016 Case IH True...
