Ignition switch is junk on my 2615
   / Ignition switch is junk on my 2615 #1
Wyld Bill
Central Maine
Mahindra
Great tiome for my tractor not to start. The middle of the winter, at night, outdoors. I go to start the tractor to scrape down the driveway so the wet snow doesn't turn to ice over night & nothing. No lights, no crank, nothing. Messed around with a battery charger to find out the battery was fine. Messed around with the fuses to find the ignition switch is open all the time between common & the IGN & Start terminals. Guess I'll be looking for at least a temporary fix tomorrow.:(
It is weird how it just quit,..I've never had any issue before:confused:
   / Ignition switch is junk on my 2615 #2
Ignition switch failure is rare on these. Generally a "no crank" issue is dirty battery cables, failed safety switch or a blown main fuse over by the starter. Sometimes the wires will get torn off a safety switch, that will also do it. We have sold several hundred of the 15 and 16 series, and have only repalced a couple ignition switches.
So have you got it fixed yet?
   / Ignition switch is junk on my 2615 #3
i have owned two of these tractors one was a repo i ended up with and one was a case 1130 which is the same exact tractor and both of them i had to change the ingition switch on both of them so it must not be to rare atleast where im at i am 2 for 2 on these
   / Ignition switch is junk on my 2615 #4
My 2615 acts up like that occasionally. What I have deduced from my struggles is either (A) the factory battery cable terminal ends are a little to big around (I've had to get shorter bolts) or the non factory (new) battery posts are smaller than the factory intended. I tighten down some more, tap around and it cranks up every time. Sounds simple but I've experienced that "now she will, now she want" several times.
   / Ignition switch is junk on my 2615 #5
Sounds like you are hard on igniition switches. :D No doubt they do fail, it just isn't common in our area. We are in a very dry area, maybe the humidity is a factor?
   / Ignition switch is junk on my 2615 #6
I'm interested in knowing more about the Case connection. I knew that Cub Cadet sold these Mitsubishi tractors as their 7200 series. How many other "American" names sold what became the Mahindra 15-Series tractors?
   / Ignition switch is junk on my 2615 #7
i know the case 1120, 1130, and 1140 where mitsubishi tractors they look identical to the mahindras
   / Ignition switch is junk on my 2615 #8
I had similar problem with switch.
Shoot some WD-40 into the key slot and that should do the trick.
They assemble the switches with a lubricant (kinda grease) that dries up with time.
The WD softens the lube and gets her going again.
I guess I never go tback to this thread. The ignition switch on these is junk!
I took the failed one apart for post mortom examination. There is a post in the center of the rotary switch. The copper plates that rotate to switch the contacts are stacked on this post or pin. THIS POST IS PLASTIC!!! So no big surprise what happened, the plates wore a deep grove into the plastic post & this was fouling things up. I bought another stock switch for now but the next time it happens I'll be replacing it with a standard marine ignition switch from Napa.
   / Ignition switch is junk on my 2615 #10
Wyld Bill, I have a 3015 that has been dead for a few days. Working fine lugging firewood, then wouldn't start. Nothing. Found the 60amp inline fuse blown. After getting new fuse at NAPA ($2.85), dealer wanted $22, i have hazards, but it blows the fuse when i turn the key to the glow plug. I put another fuse in and turned the key all the way and the starter cranked a few times before the fuse blew again. I looked at all harnesses, all looks good. Do you think it could be the ignition switch? I figure it is either the switch or glow plugs or something after the switch. If these switches are junk, it would make sense that could be it. Thanks for any input.
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2006 International 4400 DT466 (A50120)
2006 International...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
434669 (A48836)
434669 (A48836)
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
