Ignition Problem
   / Ignition Problem #1
fredbear241
Single cylinder elec start petrol Kubota. Anyone have details / links to info on Kubota ignition. It runs fine, then stops with no spark. From Ign coil there is HT lead & 1 wire. How do bypass test wire to check where prob is. This single wire seems to have ~1v when motor is running.
   / Ignition Problem #2
Fred, how old is the motor? Solid state or points type ignition? How long does it run before stopping? Does the single wire run to a grounding block for shutting off motor?
Keep the greasy side down.
Mike
2013 PETERBILT 388 DAYCAB BOBTAIL VACUUM TRUCK (A53843)
2013 PETERBILT 388...
2021 Ford F550 XL 4x4 Service Truck (A52384)
2021 Ford F550 XL...
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
1261 (A50490)
1261 (A50490)
2020 Chevrolet Express (A50123)
2020 Chevrolet...
