If mowing wasn't a factor
   / If mowing wasn't a factor #1
Gio
Nebraska
Massey Ferguson gc2400
I am shopping for my next tractor and I had a thought...
What type of tractor would I buy if i wasn't concerned about mowing? Would I be better off buying a bare bones workhorse like a JD3005 or a stripped down Kubota and a separate zero turn or rider for mowing?
I could give up a little comfort and features in my working tractor if I wasn't spending long hours in the seat mowing. Maybe I could get more tractor if I didn't care about a mid PTO or Hydro trans (things I would want for mowing).
I only mow 4 acres but it is a major factor in my decision making.
Any thoughts?
   / If mowing wasn't a factor #2
Isn't the real question what do you want to do other than mowing? If a good mowing tractor will do everything else you want, then you're set. If you're planning work that takes more like 40 hp than 25 hp, you might be better off with a separate mower. If you're regularly mowing 4 acres, I'd think you'd want a pretty good mower, so it won't be cheap.
   / If mowing wasn't a factor #3
What KennyG said. If you want a digger/ground machine and don't plan on mowing, the weight and hydraulics are king. HP is less meaningful when using the PTO is secondary. Just depends on what plan to use the tractor for. I have two machines. One ideal for mowing and snow plowing. The other is set up to dig and carry.
   / If mowing wasn't a factor #4
I mow with the '48 Farmall and do dirt with the Kubota. Even if I would mow with the Kubota there is nothing I would change about it. It works a FEL and a BH and 2 blades and a tiller. I would not do without HST or 50HP.
For mowing 4 acres I would get a ZTR, unless it was bunch grass on rough ground.
   / If mowing wasn't a factor #5
I have pretty much come to the conclusion that any one machine to "do it all" well is like the Loch Ness Monster and Big Foot, some people claim they exist, but I sure have my doubts.
Some, in limited situations, may come close, but for the rest of us, two machines are the ticket unless you are willing to make compromises in one area or the other.
   / If mowing wasn't a factor #6
TripleR is on the mark. The need to mow has hobbled up lots of folks and thier CUT's, primarily with R4 tires (mark up damp lawns almost as bad as R1's, and little more traction than turfs in mud or soft ground). Having a seperate tractor for the lawn frees you from that recipe for dissapointment and compromise, letting you get "real" tires - R1's for off the lawn and turfs for on. Depending on your off-lawn usage, you may also be better off with a gear transmission which is significantly more efficient for heavy ground-engaging work. If it is primarily loader work you will be doing however, a hydro would still be best for that, and is definitely the choice for on the lawn.
   / If mowing wasn't a factor #7
I was in the same boat as you last year... end up buying ZTR and CUT. And best decision I ever did. Not the chearper route but works for me. You have to sit down and really think what you want to do... Hope this help a little ;)
   / If mowing wasn't a factor #8
I don't think you can beat a ZTR in the mowing department regardless of what tractor you get they are just flat out mowing machines.
   / If mowing wasn't a factor #10
I agree. I have a JD riding mower for a few acres. The only "mowing" the tractor does is bushhog ;)
I used to finish mow 10 acres with a 72" RFM and it was time consuming.
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2011 INTERNATIONAL PROSTAR SLEEPER (A53843)
2011 INTERNATIONAL...
Ford Tractor (A50120)
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
