idle surge
/ idle surge #1
gumper48
ck30 with 35 hrs on it-
at idle it surges between 800 to 1100 rpm-
seems that when it is first started it will idle evenly-
when it is warmed up it starts to surge-
is there a simple adj i can make to fix this ?
thanks in advance
keith
ck30 hst
fel
bh
bush hog
grapple
landscape rake
box blade
/ idle surge #2
I don't know ANY of the specifics on that engine, but in general, surging from a diesel engine is usually caused by a fuel delivery problem, often caused by the injector pumps internal governor. First check for problems with the fuel itself. (dirt, water, ect.) Then check filters and screens. Also, it could be as simple as an injector being partially stopped up or going bad. If all the obvious things look OK, get it to the dealer/shop for an expert opinion.
/ idle surge
whatever was causing the surge worked itself out of the system-
have put another 6 or 8 hrs on her and it idles right.
thanks for the response-
keith
2016 FREIGHTLINER COLUMBIA 120 (GLIDER) DAY CAB (A60736)
2016 FREIGHTLINER...
1761 (A58375)
1761 (A58375)
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
Compressor (A55973)
Compressor (A55973)
MULCHER (A58214)
MULCHER (A58214)
