idle fast and slow
   / idle fast and slow #1
lugo2214
Hello;
got a YM2500 with a re-built engine and the shop cant get it to idle right. it turns on and it idles normal , then goes fast for a few seconds and then it slows down all without throttle movement.
they have gone thru the fuel pump adjustment according to the YM manual thet I provided them and are telling me now to replace the pump.
It did not do this prior to the repairs........
HELP??????
   / idle fast and slow #2
My money would be on a sticking or binding governor linkage. Could also be a sticky injection pump rack. There is a lot that actually goes on to maintain a steady idle. The governor is frequently adjusting the throttle up & down. A sticking linkage or rack causes those adjustments to become very noticeable.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
   / idle fast and slow #3
Hello and Welcome......
I know this will sound like a dumb suggestion.... but has the fuel lines been bled free of air ? some times it can be the simplest of things, I let mine run out of fuel once and even though I bled the lines to what I thought was good I still had what you are describing high/low idle. I know it didn't do this before it ran out, I kept working with it timing it to just before it started to idle down then I would crack the bleeder valve the air was for sure there and purged out in bubbles, it took about 3-4 more times until I got it all out, idles fine now. i won't let the fuel run out ever again;)
again this is only a question/suggestion:cool:
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2005 JLG 660SJ TELESCOPIC MANLIFT (A52705)
2005 JLG 660SJ...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
