Grading Idiot's or Dummy's guide to surveying & grading.
   / Idiot's or Dummy's guide to surveying & grading. #1
Reg
Elite Member
Idiot\'s or Dummy\'s guide to surveying & grading.
I know it can't all be learned from a few pages, but I'm looking for the "elements" of surveying, defining grade, working to grade stakes, etc.
For example, if I had a gently sloping area that a family member wanted made flat for a tennis court.
OK, so I'd have to rip up a bunch of dirt on the high side and move it to the low side - simple in principle, but how do I lay it out, work to the layout etc ?
Any couple or three hundred page books someone can recommend to get me started ?
Better still something on-line, like the introduction to hydraulics course.
BTW, I don't want to splurge a whole bunch of money on lasers, so what were the pre-laser days methods ?
   / Idiot's or Dummy's guide to surveying & grading. #2
Re: Idiot\'s or Dummy\'s guide to surveying & grading.
Okay - cheap - easy - enjoyable and does work! /forums/images/graemlins/grin.gif
Take a nice clear mug that has some concentric circles on it. Fill it with one of your favorite foamy beverages. Find a point downhill of where you are working. Quaff some of the beverage so the level is right on one of the concentric circles. Level the mug using the circle and liquid level. Look over the top of the mug for your level alignment.
There are times it's difficult to get the liquid level in the mug just right so bring a goodly supply liquid.
I have used this method to level an area. On later checking with proper instruments found it was level.
Egon /forums/images/graemlins/grin.gif
   / Idiot's or Dummy's guide to surveying & grading. #3
Egon, 12 pack will do? /forums/images/graemlins/grin.gif
I like that method. /forums/images/graemlins/cool.gif
   / Idiot's or Dummy's guide to surveying & grading. #4
Free online Hydraulics Course.
http://64.78.42.182/free-ed/MechTech/hydraulics01/default.asp
Pre Laser surveying instruments?
George Washington was a surveyor.
He used a flat piece of wood about 16x16 inches.
On two opposite sides were two identical sets of crosshairs.
The board was mounted on a tripod and you leveled it.
The board could rotate on the tripod but remain level.
Just level the board and use it like any other surveyor scope.
Line the crosshairs up to shoot a line.
You will also need a surveyer rod. A big ruler is what it amounts to.
A helper holds the ruler and you look thru the scope to read the measurement.
You want to level an area?
Think of the plane swept by the sights of the scope as it rotates on the tripod.
Just measure down to the ground from that plane to get distance.
More distance means a low spot. Less means a high spot.
To get more info about this you mite try searching out info about
laying out a house foundation using a transit level.
You can pick up a transit tool for cheap up to expensive.
Go for the self leveling type. Leveling one manually can be pain to a newbie.
Pooh Bear
   / Idiot's or Dummy's guide to surveying & grading. #5
In the early 1950's I worked for my granddad building houses.
He took a 5 gal bucket, turned it upside down & set a carpenters level on it. Worked the bucket into the ground until it was level in all directions. Then he layed a nail on each end of the level and sighted the points to shoot the grade.
   / Idiot's or Dummy's guide to surveying & grading. #6
I had a drainage ditch to dig a few years ago, about 800 feet. I used string and a line-level, starting at the high end of the ditch, and drove a stake about every fifty feet keeping the top of each stake level with the previous one. This method isn't as exact as using a transit, but it's close. After all of your grade stakes are in place you can determine how much soil must be moved.
   / Idiot's or Dummy's guide to surveying & grading. #7
If you go around corners or have other view obstructions, remember that water seeks its own level. Using a hose with equal size clear sight tubes at each end will show you the same exact elevation at each end. Just make sure the hose is completely filled with water and has no pockets of air. This method is very accurate and cheap to set up for a limited one time project if you already have some hose. $10 or less and you are ready to go.
   / Idiot's or Dummy's guide to surveying & grading. #8
You can rent a transit and a tripod from a rental center for a day, set all your stakes and then start diggin.
What I do is remove the obvious high dirt with my loader until I'm roughly close to where I want to be, then set up the transit and start pounding the stakes in. That way your stakes will all show above ground or you won't have to use real tall stakes or stakes down in a hole.
I don't know the dimensions for a tennis court, but if you can establish where one corner goes, just use the "3-4-5" triangulation principal to get it all squared-up (works for rectangle, too). You can check how "square" she is by pulling diagonals from each corner in an "X" across the tennis court.
If you're doing a tennis court, make sure you're compacting your fill to the specs needed for one.
I'm just throwing some basics at you that I use for digging house & addition foundations.
   / Idiot's or Dummy's guide to surveying & grading. #9
If your trying to level an area with a moderate slope, just grab a few gradestakes, spool of string, and a string level (All can be picked up at your local hardware store for a couple of bucks).
Put the gradestakes in the corners of your area to be leveled. Tie the string on the gradestake that is closest to the desired grade (tie string at grade level) and run string to all the other gradestakes. Placing the line level on the string half-way between gradestakes and making sure the string stays level. This will show you where the grade needs to be raised or lowered.
Here is a picture of a typical line level that I am talking about.
Good Luck!
   / Idiot's or Dummy's guide to surveying & grading. #10
</font><font color="blue" class="small">( If you go around corners or have other view obstructions, remember that water seeks its own level. Using a hose with equal size clear sight tubes at each end will show you the same exact elevation at each end. Just make sure the hose is completely filled with water and has no pockets of air. This method is very accurate and cheap to set up for a limited one time project if you already have some hose. $10 or less and you are ready to go. )</font>
That is the way I would do it.
One additional warning: Make sure that the hose is all in the shade or all in the sun. If the temp varies on one end from the other, that will also throw off the level.
A water level is nice as it can be a one-man operation. Others almost require two.
Set a master stake up in the center of your planned levelingoperation, set other grade stakes wherever you need them.
Put two nails in each stake spaced so the tubing is a slip fit.
Mark the master stake - Doesn't matter how high but be sure it is high enough that the level at the highest stake will fall at a convenient level - you don't want it down near the ground.
Fill hose, put it between the master and a grade, pull up or push down the tube at the master until the water level is on your mark. Now go to the grade stake and mark it at the water level. Repeat as necessary.
Be sure not to spill any water from the hose/tube when moving from one stake to another.
Harry K
John Deere 5410 Tractor (A44391)
John Deere 5410...
Skyjack SJ6826 RT (A42021)
Skyjack SJ6826 RT...
Chery 7' 10 Drawer Workbench (Blue) (A44502)
Chery 7' 10 Drawer...
1993 TRAILMOBILE TRAILMOBILE TRAILER (A45046)
1993 TRAILMOBILE...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A45046)
1982 TANDEM AXLE...
2010 UTILITY 53X102 DRY VAN TRAILER (A43004)
2010 UTILITY...
