Mowing Identifying Kubota finish mower
   / Identifying Kubota finish mower #1
jeffreythree
Bronze Member
Kubota B6100E
Trying to identify my mower since parts people don't really appreciate trying to identify parts for mystery items. It is a Kubota 48"(?) finish mower that has no tags I can find other than Kubota stickers and a Superior stamped on the gearbox. Supposedly been with this B6100E tractor since new. It has a label saying to run it at 2nd PTO speed and not to exceed 900 rpms. I thought this unusual since I have found most 3ph implements run at 540, and some people even comment they have not run across anything that runs at the PTO's 2nd speed. Even if someone knows where an ID tag might exist on it would help. Here are some pics of it on the tractor, but not closeups of mower by itself.
   / Identifying Kubota finish mower #2
Looks like a B3548. Do a google search for kubota b3548. You'll find some other images out there that look a lot like yours.
Nope, not that one. Thought it might be a K-348-7 but looks like that has front wheels, not chains, and rear discharge(mine is side). Forgot I brought home some chain height adjusters, did not install just to transport. There is also a tab with 3 holes in a row, which is just barely in the photo, that sticks off the rear that looks like it is used to pull a second implement, trailer, or such.
   / Identifying Kubota finish mower #4
I have one that looks like the same model. Kubota tells me it is a B3548L. If it's not, I, too, would be very interested to know the model number. By chance, does it take 16-5/8" blades with a 3/4" center hole? I'm in need of a skid, and a tensioner spring for mine.image.jpegimage.jpegimage.jpegimage.jpeg
   / Identifying Kubota finish mower #6
And, I just had another fellow, tell me, that mine is likely a K-348-7, as was also mentioned here in this thread. Like you, I'm at the mercy of others' knowledge, to figure it out.
sod roller (A52377)
sod roller (A52377)
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
Pair of New 700/40-225 Alliance Tires with Rims (A53473)
Pair of New...
2005 Sterling Acterra Tender Truck (A53473)
2005 Sterling...
2014 Vermeer SC802 Towable Stump Cutter (A51691)
2014 Vermeer SC802...
