Idenitifying Fittings
   / Idenitifying Fittings #1
wvpolekat
Platinum Member
Buckhannon, WV
1947 Ford 2N and 2003 Kubota B7500
I am getting ready to get my grapple hoses made. I know the size of the ports on the grapple valve and the cylinder. But, how do I know what size fittings to get put on the end that connects to the loader valve and what adapters are required to hook the return to the new valve?
   / Idenitifying Fittings #2
Research.
There are three types of fittings most commonly used on tractors, they are NPT, ORB and JIC. Doing google searches of these will turn up all kinds of info and pictures. You may also need a way to accurately measure what you have so you can compare them to charts.
What tractor do you have? Asking others who have the same or similar machine may be able to help also.
Here is a chart I use often: Hydraulic Warehouse - Size Chart
Thanks, I will google around and see. I can't find my memory card for the camera right now, and the phone takes terrible pictures.
This is on my 2003 Kubota B7500 with the LA302 loader. Valve is a Husco.
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
90006 (A51694)
90006 (A51694)
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
