Ideas for rear weights to balance FEL loads (post pics too)
   / Ideas for rear weights to balance FEL loads (post pics too) #1
Spiveyman
Platinum Member
Central KY
Ford 6610 II
Howdy, I started another thread asking for tips on safe operation of a FEL. I've gotten great responses. One of the suggestions was to make a rear weight, here's that post:
MarkV said:
I think a great inexpensive addition for your tractor would be a home made rear weight. You have a good size tractor and it will handle a loader that carries a lot of weight. Even with your size tractor the rear is going to get light with a full load. An effective weight can be made with a drum or garbage can filled with concrete. You get a draw bar, the type that connects between the lift arms, to insert through the can before filling. Some flat stock or even eye bolts can be set in the concrete for a connection point for the top link. A container large enough for 12 bags of ready mix gives you almost 1000 pounds and more would be even better.
A search here on the forum will show some clever ideas people have incorporated on there weights to carry chains and tools.
So this got me thinking, does anyone have any neat ideas or designs for such a weight or something similar that would be functional in some way and also really heavy. Please post pics if you have them as that makes it much easier to understand. I'm not the most mechanically inclined person on the planet. Also I can't weld, but could have someone else do that for me the ideas involve welding. This is your chance to showcase your ingenuity! Thanks in advance.
   / Ideas for rear weights to balance FEL loads (post pics too) #2
There is a thread or two on this topic somewhere on the board, I think in the projects forum.
I made one for my Kubota using a steel rod and two 5 gallon pails. I poked a hole in the end of the pails so the rod would stick through, drilled the rod to accept lynch pins. Then I cut the bottom out of one of the pails, placed them end to end with duct tape, and filled them with ready mix. After it set up I had a more or less cylindrical weight of about 125 lb or so.
On my current tractor, I have what amounts to a box shape of concrete with a hole through it in which there is a steel rod with holes in the end for lynch pins. Concrete is about 160 lb per cubic foot if I remember right. My weight is about 900 lb. You can make one whatever size you need.
The top link is secured to two pieces of 3 inch angle iron set in the concrete and drilled to allow a hitch pin to pass through for the top link. You could make one like this of whatever size you want by forming it up with 2x4 and OSB. Get a piece of plastic pipe --PVC or ABS -- large enough for your steel cross bar to fit in so you don't have to drill a 3/4" hole through 30" or so on concrete. Doing that would be a lot like work as opposed to simply setting a piece of plastic in the forms. Make sure you build the forms pretty heavy, especially at the corners, since wet concrete can spread forms easily and then you have a major mess to clean up and no weight to show for your efforts. You could use a drawbar as the attachment points for the lift arms, but a section of steel rod is a lot cheaper. It needn't be as heavy as a drawbar since all it will do is lift the weight, not pull things.
   / Ideas for rear weights to balance FEL loads (post pics too) #3
I am new to this tractor busness as well. When I bought my property I also bought a couple of the old machines. The tractor I have is an old MF-65 gas engine. What the old man did for a rear weight, which I thought was pretty good, was use a 45 gallon (Imperial gallons - a 55 gallon US drum) drum with the top cut out. A piece of pipe is put through the drum at about 2/3 height from base. A 3/4" bar put through the pipe which goes through the lift arm balls of the 3ph. The drum is filled with assorted rocks [which multiply like rabbits here :)]. To hook up I just back the tractor in place and slide in the rod and install the large flat washer and cotter pins to secure. The drum sits on a couple of concrete blocks when not is use.
Is what I am presently using and it does away with some of the rocks lying around. Oh, there are also a few holes in the base for draining out water.
This might work for you and you could always pour some cement or concrete in the drum to add even more weight and rigidity.
HTH
Jim
Oops... rookie mistake. I got all ansty and a bit too quick on the trigger. Didn't do my homework. There are some good posts out there spread around in several threads. You have to hunt, but you're right it's out there.
   / Ideas for rear weights to balance FEL loads (post pics too) #5
There was a thread not too long ago with a clever idea. I don't remember the member, so speak up if it's you. Someone made a concrete ballast box for the 3pt. However, he put PVC pipe in the box vertically and cast it with concrete. The PVC tubes were then used to carry tools such as shovels, rakes, ax, hoe, broom, chainsaw , come-a-long or whatever. Not only did he have a counter weight for his fel, but he turned his ballast box into a useful tool carrying hardware store. I thought it was a terrific idea.
Yeah, I saw that in another thread after I started this one, and the guy even posted a picture which was great. I probably shouldn't have started this thread since that one's out there, but perhaps this thread will direct others to that one. You can search on "ballast"
That was a great idea, I agree!
   / Ideas for rear weights to balance FEL loads (post pics too) #7
I've already posted in your FEL thread, including photos... yep, involves welding, but I had the pipe for the carryall, handiest thing I could have done, makes double use of the hay fork as well.. Note that some of the weights are integral to the hay fork so that when carryall is removed, there is still counter weight on the 3PH to assist/maintain balance when using FEL hay spike... of course, you should 1st put a bale on the rear THEN one on FEL spike.
   / Ideas for rear weights to balance FEL loads (post pics too) #8
No harm rehashing stuff. Sometimes new ideas pop up. One time I had to spread some dirt in a tight area and didn't want to put the blade on, so I improvised and set a 50 gallon barrel on my 3-pt with a drawbar, put a ratchet strap around it and filled it with water. I have also done the same thing in the winter except filled with sand, weight plus sand for throwing on the ice.
   / Ideas for rear weights to balance FEL loads (post pics too) #9
I prefer to put an implement there, or my carryall. Can fill it with mulch or whatever. Only problem might be if you need to work in a confined space. A ballast box or wheel weights would take up less space.
Problem with wheel weights is how one gets them up into place to bolt them to the wheel. I remember someone posted something about how they lift them into place. Saw my neighbor had some on his 4310. May have to ask him how he gets them on and off. Possibly, the tire repair guys have ways of handling them.
Ralph
   / Ideas for rear weights to balance FEL loads (post pics too) #10
Ralph,
Depending how heavy they are, wheel weights are not too bad to get on and off. You could lift them or use a hydraulic jack to position them so they catch the wheel weight lug bolts. Mine have a separate set of bolts to accept the wheel weights.
The smaller one weighs about 50lbs and the bigger one about a hundred. When I widened my rear tire stance, I put them on the inside of the wheels. In addition, my rears are loaded, so I've got an extra 900lbs for traction and stability down there.
The rears are set at their widest now.
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2014 Rockwood Premier 2317G 23FT S/A Pop Up Camper (A51694)
2014 Rockwood...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
