Colonel Monk
Gents!
Happy Pre-Turkey day to you all.
I have a WoodMax 8M we recently acquired.
Our land is quite soft. Over the years since we homesteaded on it, the openings created by the driveway and house have dried it out quite a bit, and the thick cedar swamp has begun to get more and more sparse as strong straight line winds have knocked over lots of trees. Oh, that and the damned emerald ash borer. I'm guessing that working on this clean up often, will take several months of weekends or longer. It's a huge job.
I can't access the areas off the roads with our Kubota L2250. Too heavy and not enough tires to keep it floating above the soft ground. I'm not going to haul all that stuff to the road to chip it, so I need to come up with another solution.
The first one would be a simple one. It'd take forever, but I could build like a 6 wheeled frame and just use a winch from tree to tree to pull the chipper and motor where I need it. Not ideal, but fairly easy.
What about building my own crappy version of a track chipper, minus the tracks? I'm thinking that 6 tires (I have 4 31 x 11.5 R15 already) and maybe a junkyard differential braking system I could maneuver it well enough to reach the places I need to reach. Not talking about a vehicle you'd ride really, just a frame with wheels, motor, chipper, and maybe a platform to stand on while driving it.
I have an old 1979 Jeep Cherokee I sorta plan to restore. Plan on repowering it, so the 258 6 cylinder which runs well could provide the power and transmission. It makes nearly max torque at 1500 rpm, and first gear and reverse both have a 3:1 gear ratio which would be good for driving the chipper. Was thinking of using the rear wheel drive of transfer case to drive chipper and front wheel drive to move it around? That way I can turn off the wheel drive by shifting into 2 HI. Use 4 LO and low engine rpm to drive it around.
Am I crazy? Have watched some guys make tracked vehicle drives on Youtube from a rear differential which got me started thinking about this.
Don't have to use the Jeep motor, it is kinda heavy..... But it's got the power and transmission.
Hmmm.....
CM
Hmmm.....
CM
