ideal rpm during break-in period
   / ideal rpm during break-in period #1
deepsnow
Bronze Member
bayview township, bayfield co. WI
NH TC25D
NH TC25D @ dealership waiting for FEL. Question: What operating rpm is recommended during the first 150 hours for optimum "break-in"? Does it make a difference if your are in low, med. or high range? Heavy or light work load. The first 150 hours will probably be spent grading XC ski trails, grading the "driveway", moving piles of earth (if the piles are not frozen by the time the FEL arrives) and moving tons of snow(average around 16 feet of snow, heavy snow seasons have exceeded 24 feet). This is my first tractor and first diesel anything. Major league knowledge & experience gap.
   / ideal rpm during break-in period #2
Deepsnow, you probably want to keep it 200-300 rpm below wide open, but keep the rpm up enough that you never "lug" the engine, and vary the rpm instead of keeping a steady rpm. And 50 hours is plenty long enough to consider a "break-in" period. As a practical matter, I'd just say to run it like you intend to use it in the future.
   / ideal rpm during break-in period #3
deepsnow - Bird pretty much summed it up. You can keep your eye on the exhaust (when it's safe to do so - remember: safety first!!!) - if it's putting out black smoke, ease up a bit. More importantly than the load, though, since cold weather is coming, is using the right viscosity oil for the temps you're going to be running the tractor in, and making sure you let it warm up according to the manufacturer's recommendations before using it. Make sure your diesel fuel is winterized, too - you can do that by just buying on-road fuel at any major truck stop after it gets cold. Do those things, and you won't have any trouble, or if you do, it won't be your fault.
MarkC
   / ideal rpm during break-in period #4
wow ... now THAT'S a signature file!
   / ideal rpm during break-in period #5
Hey Bird! I echo what Mikim said about your signature. Wow! Now there's two "bald eagles" in all your posts.
/w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
JimI
   / ideal rpm during break-in period #6
Interesting points about Diesel Break-In
<A target="_blank" HREF=http://http://www.ford-diesel.com/contents/getitems.php3?Breaking%20in%20a%20Diesel%20Engine/>BreakIn</A>
2006 Cadillac Escalade AWD SUV (A50324)
2006 Cadillac...
2020 POLARIS SPORTSMAN 450 4 WHEELER (A51243)
2020 POLARIS...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2016 CATERPILLAR 325FL CR EXCAVATOR (A51242)
2016 CATERPILLAR...
