I3040 axle stops
   / I3040 axle stops #1
Taylortractornut
Elite Member
Iuka Mississippi USA
3550 Fard Backhoe and a 1948 Farmall Cub,
I wanted to let anyone with an LS to check the steering axle stops. We were servicing dads I 3040 Thursday and had the right front wheel off getting a bale twine out from around the front hub. I looked down and noticed the bolt thats the steering axle limit had back out to the last 2 threads. It had backed out and the axle housing stub bent it and messed up some of the threads in the hub housing. The jam nut had backed off and was loose on the other side but hadnt moved out. I chased the threads out in the hub housing and put a new bolt and jam nut with some locktite on both sides.
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
