i1046 electical problem ?
   / i1046 electical problem ? #1
grahamk
When i turn the key on my i1046 (zero turn lawn tractor) I get nothing on the LED readout, which I believe used to light up as soon as the key was turned. But I can't exactly recall (funny how these things pass you by).
The starter will engage, it will not fire. Fuel pump is working fine. Seems to me that I'm not getting spark.
Before I start tearing this thing apart, is this indicative of any common known issue?
Thanks!
Graham
   / i1046 electical problem ? #2
first off, check your manual - I believe there is language in there that details what you should/should not see when switching on. Secondly, would suspect the switch itself... BUT would advise taking plenty of pixs/note before starting unhooking wires/harnesses/connectors/etc.... and only replace with OEM parts ( have read too many horror stories of people buying aftermarket noname parts -switches in this case - and getting burnt - literally.)
Oh - most common problem cause for this? tractor washed down with garden hose or power washer.....
Thanks - yeah the hour meter does not come on, which it should. The starter turns, but nothing happens. No water involved. I was sweeping the lawn and stopped to empty the hopper and it would not start again. It's been very reliable to this point other than the switch on the brake needing to be replaced. I guess it's time to start tearing into it. Ugh.
I thought i'd probably find a cub cadet electrical problem troubleshooting steps list someplace, but no luck. with the myriad of safety switches this thing has it's a wonder it ever runs at all. ;-)
Ooops - forgot my "cub cadet troubleshooting 101" skills and just played around with jiggling wires for a bit until I found the connector that had come loose, and viola! a working tractor again. Argh. But yay!
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2013 VOLVO VNM DAY CAB (A51222)
2013 VOLVO VNM DAY...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
