I want to add a power outlet on a T1510....
   / I want to add a power outlet on a T1510.... #1
wny770
WNY
Lots of old iron
I have a T1510 that I would like to add a power outlet on. Has anyone done this, or know of a good source for one? I have a spotlight, and a beacon that I would like to use occasionally. Thanks!
   / I want to add a power outlet on a T1510.... #2
There are two worklight options for your tractor. One is mounted on the right fender and the other up on the ROPS. Both have pigtail wiring harnesses that must connect into an existing harness on your tractor. I'd look behind the operator's seat for an unused connector and test it for power with a voltmeter. The connection might be near your existing lights also. You can probably use that connector or splice in power to your outlet from those wires as long as you don't exceed the current rating of the associated fuse.
I have the ROPS mounted work light, and it works great. I would like to add a "cigarette style" power outlet in the dash, for a corded spotlight, and a yellow beacon, for snowplowing. I had one on my old TZ25, and used it quite often. Since my last post, I found what I am looking for at my local NAPA. Now, just have to "correctly" wire it in. was curious if anyone has done this to a T1510-20 or TC30???
   / I want to add a power outlet on a T1510.... #4
Aha! I can tell you are way ahead of me on this one. Good luck with your mod. I'm sure I'm not the only one who would enjoy a photo when you finish.:thumbsup:
   / I want to add a power outlet on a T1510.... #5
I would start with the owners manual if you have access to oone. My TC40DA manual states fuse #6 (10 amp) is for the hazard flashing lights and aux power socket. #7 (15 amp) is for the front headlights and aux rear work lights.
I do, and I will. I've bought a power outlet from Napa, and have briefly looked things over... but with a high of 12 degrees for this weekend, this project may be pushed back just a few weeks. I know, I know, I'm a baby... but no heat in the barn:)
   / I want to add a power outlet on a T1510.... #7
I added one on my TC18 by running a wire from the starter solenoid battery lead post to the power outlet using a 30A inline fuseholder. If your load is smaller, you can always use a smaller fuse.
I was going to run a 10 amp fuse? I thought this would be more than plenty for a spotlight, or a rotating beacon. I will check the spotlight's rating to make sure. Thanks for the note.
6 ft. Rotary Cutter (A53117)
6 ft. Rotary...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
