I think it is stuck (pic)
   / I think it is stuck (pic) #1
JayDavis
Bronze Member
East Texas
Fiatagri 90-90
Hey, here is a picture from where I work. This electric dragline was sitting on a "bench" of spoil dirt digging out the bottom of the pit when the ground under it started to slough down.
For scale, those dozers are D10s I believe. The dragline boom is 310ft long and weights somewhere between 7 and 13 million pounds. Just remember next time you are stuck.... it could be worse. Enjoy.
   / I think it is stuck (pic) #3
Jay, could you post a pic of your Fiat also? I don't see very many of them around. Actually, I think I have only ever seen one. Most are Fiat made Hesstons.
   / I think it is stuck (pic) #4
Some days nothing goes right! You can also get a good idea of the size of that thing looking at the stairs, deck, and access door on the (unintentionally) elevated end of the machine.
These monsters are awesome. 18 years ago, right after I joined this company, we designed a flywheel-motor-generator set for the (then) largest crawling dragline in the world. The flywheel weighed 10,000 lb, and the whole M-G set acted as part of the counterweighting in the rear of the machine. I never got to see the machine in person, as it was in Australia, but the M-G set was something. When you supplied high pressure oil to the bearings ("oil lift"), a single person could turn the 10,000# flywheel and both attached rotors by hand!
Thanks for the pic!
   / I think it is stuck (pic) #5
Very IMPRESSIVE !!!!
I love that show called Mega Machines. They should do an episode on that machine and how they get it back to level ground again. I know I'd watch it.
Thanks for the picture,
Eddie
   / I think it is stuck (pic) #6
I hope there is more to this story. The need for well packed firm ground under a behemoth like this, is well known and rather obvious.
   / I think it is stuck (pic) #7
I'd prefer not to be the dozer digging under the back of that thing!
This is in a coal mine in east Texas. It is the largest dragline in operation at the mine. I don't know if it operates on the spoil side of the pit normally, but the draglines rarely get stuck, and this is the first time it has been this bad. The dozer are pushing dirt from behind it to the front, filling in the pit to keep it from going forward. Now I believe they are using excavators to dig out from under the back a little at a time so it rocks back slowly. I believe they are shooting lasers from different angles to measure its movement. M.S.H.A. inspectors were on site that day, so they must have given the ok to start moving material from around it.
The dragline moves by a set of feet on either side (things up in the air in the pic), attached to cams. So when the cams rotate they pick the feet up and back, setting them back on the ground and partially lifting the rear of the machine. As the cams keep turning it drags the machine backwards. Not seen in the picture is its bucket which, if I remember, holds about 120 yards of material.
Lastly to Robert, the tractor I have was my grandpa's, a FiatAgri Hesston 90-90. Here is the only pic of it I have on hand....this is a tractor forum after all, might as well be a little on topic. She is awfully muddy. She was mucking out a 10ft wide x 20ft long (10ft + 10ft ramp) x 7ft deep hole that had some water in it from a rain. She got washed off and greased afterwards. Currently she is at a shop in Sulphur Springs, TX getting a new clutch assembly and her steering reworked, and whatever else I can afford to have replaced. She has 2700 hours and is about 24 years old.... oh yeah, I have since found where papa hid the side access panels and put them back on. :D
   / I think it is stuck (pic) #10
Thanks for the pic. I don't mind a little mud on the tractor. There were not very many Hesstons sold even though they were good tractors.
I did manage to find one parked on the next road over. Who ever owned it did some work to it and either replaced the motor or added something to it as it had some home made alterations to the sheet metal. I couldn't go look it over too well as it was parked on posted property.
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
