Muleskinner
My dealer recieved his first M59 last week, with no back hoe. So I drove there and gave it a good look over. WOW! This is a very, very, nice machine. The best way to describe it is it's an L39 on steroids! It's almost an EXACT copy of the L39 with a few differences.
The front axle looks to be the same size as the one on my M7040HD, just not as wide. Very heavy duty and strong looking. The front tires are not as wide as my R4's on my M7040.
The only thing I don't like is the tractor uses the same spur gear rear axle as the L39. Bigger, but the same design. Now it's not that I have a problem with the spur gear rear axle design, it's just that the lower bars for the three point hitch are attached to the tractor via a pin that is mounted to the rear axle housing casting.
Last year I backed into a stump that I did not see with the right rear of my box blade on my old L39 and broke off the piece of casting that holds the pin. $1,500.00 later my dealer repaired the problem. If the axle was a planatary design like the L48, or my M7040, the lower bars would be attached to the rear axle via a pin that is welded to a heavy steel plate bolted to the bottom of the rear axle housing. If you break the pin off, all you have to do is remove the plate and weld a new pin on the plate, or reweld the original pin back on the plate. Worse case senario you would have to buy a new mounting plate. But none of the options would cost $1,500.00!
Other wise the tractor should be a home run for Kubota.
