Mowing I need some advice on mowing
   / I need some advice on mowing #1
Brokken
Sudbury, Ontario
Kubota 4740
Hello all, I am running a Kubota 4740(30 hp pto), and have a 5 foot brush hog. I am responsible for cutting hay/grass over 170 acres of fairly rough terrain in northern Ontario. Last season I cut for over 400 hours, and only completed about 115 acres.
I need some advice. Is there an attachment that would be better suited?
I would appreciate any of your thoughts.
- thank you
   / I need some advice on mowing #2
Sounds like you need a bigger tractor and a big flail mower.
Yeah, a new tractor is not really an option for me.
I was wondering if a small flail would allow me to cut significantly faster?
Or what about a sickle, or a haybine(new holland 488)?
I have no experience at all with anything besides the hog.
-cheers.
   / I need some advice on mowing #4
I'm confused. Did it take you 400 hours to mow 115 acres? That is 3.5 hours per acre! You can travel faster with a bush hog or diskbine that you can with a sickle. Are you trying to cut it for baling are just weed control. I think a bigger tractor and larger bush hog is needed.
Hi, I'm cutting for control. The fields I am cutting are interspersed by forest. So 400 hours was a generalization, which included drive time to different areas, maintenance, and odd jobs. Also the area has a few creeks that are hard to traverse, so it can take some time to get around.
It's good to know that the sickle is much slower.
-thanks
But would a 9 foot sickle be slower than a 5 foot brush hog?
   / I need some advice on mowing #7
The nice thing about a bush hog is they're generally bullet proof. If you maintain them. Grease level in gear box, etc. Does this unit have a shear pin or slip clutch on the PTO shaft? If it's a slip clutch of some kind make sure it's working properly. If it isn't it will result in gear box damage, which is pricey. this I know.:D
i don't think you're going to be able to cover ground any faster with anything else for mowers.
   / I need some advice on mowing #8
He mentioned rough terrain. A sickle wouldn't be advisable for that IMO.
I think the best solution is a bigger brush hog.
   / I need some advice on mowing #9
With a 30pto tractor he could move up to a 6ft mower. If the grass/hay isn't to high probably pick up the speed a bit.
   / I need some advice on mowing #10
The L4740 is rated at 40-41.5 PTO HP. The OP can run a much bigger cutter.
1992 Kenworth T800 Semi (A50514)
1992 Kenworth T800...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2013 Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
2013 Case 84in...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
